Activity › Forums › Apple Final Cut Pro Legacy › How do I view the image on my moniter in real time?
Posted by Sally Obrien on May 29, 2008 at 2:50 amWhat device do I need to be able to view the video on my moniter in real time? When I’m editing right now I have firewire connected to my camera, and then AV plug-ins go from there to the television (so there’s a 1 second delay or so).
Sal
Lu Nelson replied 18 years, 3 months ago 6 Members · 14 Replies -
Tom Wolsky
May 29, 2008 at 3:32 amAre you talking about DV? The lag is the time to make the digital to analog conversion. You can’t get rid of it.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
Rafael Amador
May 29, 2008 at 3:37 amHi Sally,
Try adjusting: System Setting> Playback Control> Frame Offset.Mac OX 10.5.2-FC 6.02-QT 7.4.1
G5 2x2Gh 4GbRAM-BlackMagic Extreme
PMBP 17″Core2Duo 4GbRAM-AJA ioHD
JVC DTV-17″
SONY EX-1 . SONY PD170
..and always a big mess on top of the table. -
Tom Wolsky
May 29, 2008 at 3:41 amThat adjusts the audio timing on the computer to match the video on the external monitor. It’s not a function that should be used.
All the best,
Tom
Sally Obrien
May 29, 2008 at 3:54 amI guess I was wondering if there was something similar to the Matrox Breakout box that Adobe Premiere uses. When I’ve used that on Premiere there’s no delay from Computer moniter to the TV screen.
Sal
Rafael Amador
May 29, 2008 at 4:40 amYou are absolutely right Tom.
Sorry Sally. I’ve read your post to fast. Thought you were talking about the audio delay.
As Tom says, there is nothing to do. The signal takes longer to get in your monitor than in your Mac screen.Mac OX 10.5.2-FC 6.02-QT 7.4.1
JVC DTV-17″
Shane Ross
May 29, 2008 at 5:23 am[sally obrien] “I was wondering if there was something similar to the Matrox Breakout box that Adobe Premiere uses”
Well…yeah. There is the Matrox MXO. Bonus with that is that you can use your Apple Cinema Display as an HD broadcast quality color correction monitor.
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.LFHD.net
Read my blog! -
Lu Nelson
May 29, 2008 at 1:17 pmYeah but…well this is OT; but the MXO does have a significant lag time too. Not 1 second, but about five frames which is why I only use it for review and correction. I edit with Digital Cinema Desktop as its got the lowest lag time of any setup I’ve tested.
Just get a second monitor for your system and select “Digital Cinema” as your preview type
LMN
Lu Nelson
Berlin, Germany -
Shane Ross
May 29, 2008 at 2:31 pmLu, I have not noticed any lag time with the MXO. None. You need to go into the SYSTEM SETTINGS, Playback Control tab and set the FRAME OFFSET to 0. The default is 4…and that makes playback to external monitors off sync.
Shane
http://www.LFHD.net
Read my blog! -
Walter Biscardi
May 29, 2008 at 2:42 pm[Shane Ross] “Lu, I have not noticed any lag time with the MXO. None. You need to go into the SYSTEM SETTINGS, Playback Control tab and set the FRAME OFFSET to 0. The default is 4…and that makes playback to external monitors off sync.”
And to add to this, it’s the same with any video card or playback device. Unless otherwise stated, playback offset always has to be reset to 0 to ensure your playback is in sync. This is the same with the AJA Kona boards and Io devices.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Lu Nelson
May 30, 2008 at 7:20 amWow. For real?
Maybe we’re talking about slightly different things: I think with the playback offset you may be able to have the Canvas and the MXO in sync; but what I meant with the MXO is that it’s the shuttle delay I can’t stand. It doesn’t stop when I want to stop/start/change directions as fast as Digital Cinema Mode does.
Is it that way in your set up? If not, then there’s something really wrong over here.
Lu Nelson
Berlin, Germany
