How do I use a hi con clip to create a transition
I’m sure the answer is right under my nose but I’ll ask anyway. I’d like to use some hi-con clips (erasing a chalkboard or a glass shatter for example) to get from clip A to B . I’ve tried stacking the tracks different ways each time going through all the composite modes and I don’t get a the desired effect. The video is from digibeta and comes in 10bit sdi to my MacBook Pro via Aja LD. What an I not thinking of? Thanks in advance for your help!
