Activity Forums Adobe After Effects How do I stop an animation preset after a certain number of times?
  • How do I stop an animation preset after a certain number of times?
    Posted by Rosaleen Donnan on August 3, 2011 at 7:51 pm
    Hello there
    Firstly, huge apologies because I am extremely new to AE and teaching myself!
    I am using CS3 and have added the AE text animation preset Broadway to some text but I would like it to stop animating after it has rippled through the text a few times, say 10 times.
    I don’t understand the coding in the expression to be able to control it there.
    f=effect(1)(1);
    div = Math.abs(Math.sin(2 * textIndex/textTotal – time*f)*100);
    result = 0;
    if (div) {
    result = 300/div – 3;
    I split the layer at the point where I would like the preset to stop animating but I am not sure how to subsequently then take the preset out of the split layer because if I remove parts of it I break the look of the original text!
    Any wisdom and insight would be gratefully received! Many thanks!
    Rosaleen Donnan replied 15 years, 1 month ago 2 Members · 2 Replies
  • Michael Szalapski
    August 3, 2011 at 9:00 pm
    My AE machine is busy at the moment or I’d test this, but I wonder if one way to do it would be to keyframe a slider (Effect>Expression Controls>Slider) from 100 to 0 and replace the 100 part of the expression with the value of the slider.
    I’m not sure though as expressions aren’t my thing.
    Since you’re new to AE, I’d suggest a few resources to you to help you learn. To start you off go here: [link] It’ll build a great foundation in the basics.
    This product goes a lot more in-depth and is totally worth it: https://www.peachpit.com/store/product.aspx?isbn=0321734866
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Rosaleen Donnan
    August 4, 2011 at 8:32 pm
    Thanks for your suggestion and for your tips on getting started with AE.
    In the end, I split the layer at the point in the time line where i didn’t need the animation any more and then selected ‘remove all text animators’ from the menu on the new split layer … seems to work!
    I love your AE reel by the way 🙂
