Activity › Forums › Adobe After Effects Expressions › How do I simply loop a composition?
  • How do I simply loop a composition?
    Posted by Daniel Haskett on May 12, 2005 at 12:02 pm
    Hi there
    Basically all I want to do is create a composition that is say 5 seconds long of some objects moving, and then put this into another composition but then loop it. I cant work it out… I know you can loop footage but how about a composition?
    thanks!
    dan
    Ala Mctoom replied 14 years, 4 months ago 3 Members · 2 Replies
  • Steve Roberts
    May 12, 2005 at 12:47 pm
    Apply time remapping (TR) to the sub-comp, then apply the “loop_out” NumKeyframes expression to the TR property. You should be able to use the default expression.
    Steve
  • Ala Mctoom
    May 9, 2012 at 1:31 pm
    That helped me. Thanks!
