Activity Forums Adobe After Effects How do I set Render Q Output module compression prefs.
  • How do I set Render Q Output module compression prefs.
    Posted by Steve Dann on May 25, 2010 at 12:01 am
    How can I make 16:9 DV PAL the default render queue compression setting? AE always reverts to ‘Animation’ at 30fps every time I change it. Is this because I’m moving between projects? Must be in preferences somewhere?
    Todd Kopriva replied 16 years, 3 months ago 2 Members · 1 Reply
  • Todd Kopriva
    May 25, 2010 at 2:14 am
    See “Create, manage, and edit output module templates”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
