Activity Forums Avid Media Composer How do i see a client monitor with Avid Mojo?
  • How do i see a client monitor with Avid Mojo?
    Posted by Revmilo on October 18, 2007 at 1:48 pm
    Hi
    I use AFX 7.0 and Avid Xpress Pro 5.6 on the same machine. The driver for the Avid Mojo to work with the client monitor is not compatible with being able to see AFX on the client monitor. Any idea how i can fix this problem?
    Milo
    my system is as follows:
    Dell 670
    3 Gb RAM
    Windows XP – Service Pack2
    NVIDIA Quadro FX 3400/4000
    Avid Xpress Pro – 5.6.6
    Mojo version 1
    After Effects 7.0
    Thanks in advance
    Bouke Vahl replied 18 years, 9 months ago 4 Members · 3 Replies
  • Michael Hancock
    October 18, 2007 at 4:56 pm
    Did you install Avid EMP? It’s a seperate installer on your Avid install disk. Install that, then you have to go your AFX Preferences and set it to use the Mojo. It should work-we had it working at my last job.
    Michael.
  • Richard Sanchez
    October 18, 2007 at 4:57 pm
    When you installed your Avid application did you install the After Effects EMP? The Mojo driver alone won’t send the signal from After Effects to the client monitor. Once you install the After Effects EMP, you should see the option to send the signal out on the “Edit” pulldown menu.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Bouke Vahl
    October 22, 2007 at 6:38 am
    Did not try it lately, but i had a situation where avid HAD to run in the background to get it work, while others reported just the opposite. So try both…
    hth
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
