Activity › Forums › Apple Motion › How do I Scale Particle Emiters so that their emmisions look consistant as they scale?
  • How do I Scale Particle Emiters so that their emmisions look consistant as they scale?
    Posted by Matthew Woods on December 19, 2006 at 5:38 pm
    I have a project where I have animated a steamboat moving through 3d space starting small on the horizon, then filling the frame in AE. I was wanting to take a render with an alpha into Motion, and animate particle emmiters for smoke to follow its smoke stacks. The problem is, because Motion has no 3d capability, I have to scale the emmiter over time to match the perspective of the boat’s motion. When I do this, some of the relevent properties of the particles scale with the emmiter, but others don’t so the smoke changes density and look. I could render out the smoke shape as a flat layer and bring it into AE to parent to the boat, but that will make the smoke look flat and parented to the boat. I was really hoping to be able to get the look of the smoke particles trailing off and dissapating into the distance. Any suggestions?
    -Matt
    Jim Kanter replied 19 years, 9 months ago 2 Members · 1 Reply
  • Jim Kanter
    December 19, 2006 at 9:46 pm
    Try putting a Ramp behavior on the scale parameter in the emitter. Right-click on the SCALE name in the Inspector, choose RAMP and then adjust the settings in the Behaviors tab.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
