Activity Forums Adobe After Effects How do I revert from 180×135 to 1440×1080 using “replace footage” and still have all my timeline transforms act right?
  • How do I revert from 180×135 to 1440×1080 using “replace footage” and still have all my timeline transforms act right?
    Posted by Chance Turcotte on January 3, 2009 at 5:31 am
    I rendered my 1440×1080 footage at 1/8th its orginal size so it would be much faster to work with. When I finished my project, I thought I could simply use “replace footage” to bring back my good quality footage, but now my move and resize transforms are all misplaced. Thanks for your time and any help you can give me in this matter!
    Chance Turcotte replied 17 years, 8 months ago 3 Members · 3 Replies
  • Jan Sherlink
    January 3, 2009 at 4:03 pm
    Set your original 1440×1080 file as a proxy to the downscaled ones, and render out with the setting “enable all proxies”
    Next time,
    work the other way around,
    set the downscaled files as a proxy to the originals !!
    cya,
    Jan
  • Roland R. kahlenberg
    January 4, 2009 at 5:05 am
    What Jan says is correct. For now, you can try the Scale_comp javascript that comes installed with AE. It’s in AE’s application folder within a sub-folder called, Scripts. To rn it, select the comp from within the Project Panel (don’t forget to make a backup copy of the comp – so that you have the original as a reference) and run the Script from the Project Menu.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Chance Turcotte
    January 4, 2009 at 8:34 pm
    thanks jan and roland! i figured it had something to do with proxies! it’s just been a long time since i saw a lynda.com training video explaining how to use them.. and you saved me lots of time having to skim through all my training videos trying to find the answer to this. Thanks again for helping out the community here!
