Activity Forums Adobe After Effects How do I put video inside of text and add a stroke border?
  • How do I put video inside of text and add a stroke border?
    Posted by John Corino on April 25, 2009 at 3:22 pm
    I have two layers, top is text, bottom is video. I changed the track matte to the video to alpha matte, and it works great. But I can’t get a stroke border around the text. I got it to work by duplicating layers and messing with the transfer modes but the edges are really jaggedy. Is there a simple solution to this?
    Gunnar Refardt replied 15 years, 6 months ago 4 Members · 5 Replies
  • Steve Roberts
    April 25, 2009 at 4:35 pm
    How about duping the text layer and setting the dupe to stroke with no fill?
  • John Corino
    April 25, 2009 at 5:03 pm
    I can’t believe I didn’t think about that.
  • Gunnar Refardt
    April 26, 2009 at 7:17 pm
    if you are in CS4 you could just use the stroke layer effect.
  • Nate Moot
    February 13, 2011 at 2:36 am
    can you expand on how to do this please? im still having trouble. i got up to changing the track to alpha matte and have the video i want playing inside, but still cant get a boarder around the text.
  • Gunnar Refardt
    February 13, 2011 at 3:29 am
    after you did that track-matte thingee you select the video layer and got to: layer -> layer styles -> stroke.
    if you then twirl down your layer in the timeline, you have another instance under the transform parameters. you guessed it: layer styles. you can then modify the stroke’s parameters there.
    you might want to precompose that, because i think there’s some issues with layer styles und certain circumstances. unfortunately i can’t recall what they were.
    hope that sorts that out for you.
