Activity › Forums › VEGAS Pro › How do I open an XDCAM file in Vegas?
  • How do I open an XDCAM file in Vegas?
    Posted by Stephen Mann on February 13, 2013 at 10:11 pm
    I have a client who gave me an XDCAM Quicktime file to add to his project, but Vegas 12 doesn’t like it.
    Mediainfo says:
    General
    ….background.mov
    Format : MPEG-4
    Commercial name : XDCAM EX 35
    Format profile : QuickTime
    Codec ID : qt
    File size : 310 MiB
    Duration : 1mn 12s
    Overall bit rate mode : Variable
    Overall bit rate : 35.8 Mbps
    Encoded date : UTC 2013-02-13 18:36:42
    Tagged date : UTC 2013-02-13 18:42:35
    Writing library : Apple QuickTime
    Media/UUID : 3A1CF9BC-00F6-4897-9A84-B9FAEF74B99B
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@High
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Codec ID : xdvd
    Duration : 1mn 12s
    Bit rate mode : Variable
    Bit rate : 34.3 Mbps
    Maximum bit rate : 35.0 Mbps
    Width : 1 888 pixels
    Original width : 1 920 pixels
    Height : 1 062 pixels
    Original height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.713
    Stream size : 297 MiB (96%)
    Language : English
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Tips would be appreciated.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
    Tom Pauncz replied 13 years, 4 months ago 4 Members · 15 Replies
  • 15 Replies
  • Mike Kujbida
    February 13, 2013 at 11:10 pm
    Steve, try and get a copy of the original info from your client.
    Assuming it’s from a card, have him copy the contents of the entire card to a drive and give that to you.
    Grab a copy of XDCAM EX ClipBrowser and use this to extract the information from it.
    I keep it in my Dropbox folder because I get tired of searching for it every time someone is looking for it.
    https://dl.dropbox.com/u/20488019/XDCAM_ClipBrowser_V2.6.0.zip
    If he no longer has the card but has FCP, have him render it out in ProRes as I know Vegas will read that.
  • John Rofrano
    February 16, 2013 at 12:35 pm
    [Stephen Mann] “I have a client who gave me an XDCAM Quicktime file to add to his project, but Vegas 12 doesn’t like it.”
    That’s because the client’s Mac as already munged the video into a QuickTime container which Vegas isn’t expecting. Tell your client that you’re not a Mac shop and, as Mike said, require the original source files from the camera in order to work with them.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    February 16, 2013 at 3:31 pm
    Thanks, john. I had him send me a ProRes file and I’ll be sending a DNxHD file back when finished.
    Steve Mann
    http://www.mmdv.com
  • John Rofrano
    February 17, 2013 at 12:26 am
    [Stephen Mann] ” I had him send me a ProRes file and I’ll be sending a DNxHD file back when finished.”
    Yea, it’s a shame that the Mac doesn’t use native formats but I understand why they do it. Glad you got something that works.
    ~jr
  • Stephen Mann
    May 13, 2013 at 3:16 am
    Same client, but this time he handed me the SD card right out of the camera. Mediainfo says the files on the card are XDCAM EX 35, MPEG4 in a MOV container:
    General
    Complete name : Z:tempThe Waiting Room200_0014_01.MOV
    Format : MPEG-4
    Codec ID : qt
    File size : 172 MiB
    Duration : 40s 541ms
    Overall bit rate : 35.6 Mbps
    Encoded date : UTC 2013-05-12 17:34:30
    Tagged date : UTC 2013-05-12 17:34:30
    The program, XDCAM ClipBrowser doesn’t see it because it’s an MOV file.
    Any tips to open this would be appreciated…..
    Steve Mann
    http://www.mmdv.com
  • Mike Kujbida
    May 13, 2013 at 3:36 am
    Steve, no guarantees but see if the free XDCAM .MOV to .MXF file converter on the Convergent Design site will do the trick.
    https://convergent-design.com/Downloads.aspx#nanoFlash-7
  • Stephen Mann
    May 13, 2013 at 5:48 am
    Wow! Thanks Mike, this was exactly the tool I needed. It worked.
    Which is great because I will be getting more files from this camera.
    Steve Mann
    http://www.mmdv.com
  • Mike Kujbida
    May 13, 2013 at 10:58 am
    Steve, I’m really glad to hear that it worked for you. Sometimes I get lucky with things like this 🙂
  • Tom Pauncz
    May 25, 2013 at 1:57 am
    Steve,
    I need to use this tool too.
    How did you get to run it on 64bit Win7? All I get is a quickly disappearing commandline window..
    Thx
    Cheers for now,
    Tom Pauncz
    (30WEST MEDiA GROUP)
  • Stephen Mann
    May 25, 2013 at 6:22 pm
    Bumblebee.
    I probably have both the 32-bit and 64-bit Java Runtime Environments loaded. I don’t recall installing it, and I didn’t notice it in the requirements.
    Steve Mann
    http://www.mmdv.com
