Activity Forums Boris FX Particle Illusion how do i move the position of an item?
  • how do i move the position of an item?
    Posted by Fall4mui on November 9, 2007 at 3:23 am
    as stated above, lets say i wanted to move an image from the top right to the bottom left, can i? and how? sorry if this is a beginner question
    thanks
    Sockratease replied 18 years, 10 months ago 2 Members · 1 Reply
  • Sockratease
    November 9, 2007 at 5:08 pm
    I would just make the image a particle (checking the “single particle” option) and treat it as any other emitter. Move it at will along the timeline.
    You may be able to use layer offset too… I need to experiment with that feature more!
    Maybe someone else has a better answer, but that should work.
    MOO!
