Activity Forums VEGAS Pro How do I move the contents of a clip forwards or backwards on the timeline without moving the clip?
  • How do I move the contents of a clip forwards or backwards on the timeline without moving the clip?
    Posted by Neil Pollick on May 9, 2018 at 8:50 pm
    I still want the clip to be in the same part of the film, to still start and end at the same time but I want a different part of the clip to show in that space.
    I can do it manually but maybe there is a simple way such as holding a key when the edit tool is on the chosen clip then dragging it right to bring in an earlier part of the clip, or dragging it left to bring in a later part of the clip.
    If there isn’t a way then there should be!
    Maybe the question has been answered but I wouldn’t know what keywords to search on for this technique.
    Neil Pollick replied 8 years, 3 months ago 2 Members · 2 Replies
  • John Norton
    May 9, 2018 at 10:26 pm
    Slip tool ..
    Extract from the manual below ..
    “Slipping and sliding events
    To help you picture what happens when you slip and slide events, think of an event as a window to a media file. The window can display the entire media file or a small section. When the window displays only a portion of the media file, you can move either the window or the underlying media to adjust the media that is played by an event:
    When you slip an event, your event maintains its place on the timeline, but the media file moves in the direction you drag.
    When you slide an event, the media file maintains its place on the timeline, but the event moves in the direction you drag.
    If you want to slip all of an event’s takes when slipping media, make sure Slip All Takes is selected in the Options menu. For more information, see “Using takes as alternate versions of events” on page 182.
    Shifting the contents of (slipping) an event
    Use the Slip tool or hold Alt while dragging an event. The slip cursor is displayed.
    As you drag the event, the contents of the event shift, but the event will not move. You can use this technique when you want to maintain an event’s length and position, but have the event play a different section of the source media file.
    For more information about the Slip tool, see “Editing Tool” on page 19. Slip-trimming an event
    Use the Slip tool or hold Alt while dragging the right or left edge of an event. The slip-trim cursor is displayed.
    As you drag the event edge, the opposite edge of the event will remain fixed, trimming the media from the edge you drag.
  • Neil Pollick
    May 11, 2018 at 5:41 am
    That’s it!
    Thank you
