Activity Forums Adobe After Effects How do i move Compositions from Project to Project?
  • How do i move Compositions from Project to Project?
    Posted by Colin De jose on June 29, 2007 at 8:08 pm
    Silly Question, but i just can’t figure it out. I have compositions in one project that i want to take to a better timeline, and i don’t want to render it and then put in a quicktime movie.
    Should i just import the project into the new one and then delete the stuff i don’t want?
    cdejose
    Roland R. kahlenberg replied 19 years, 3 months ago 3 Members · 2 Replies
  • Brendan Coots
    June 29, 2007 at 8:24 pm
    As you said, you should just import the project and delete the stuff you don’t want.
  • Roland R. kahlenberg
    June 30, 2007 at 10:20 am
    A better way is to select the comp(s), from the Project Panel, that you want to keep or bring into another AEP and then goto File->Reduce Project.
    That will delete all other comps but it will retain related precomps. This makes the Project Panle lean and much easier to incorporate into other AEPs.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
