Activity Forums Adobe After Effects How do I move a camera through dust particles created with CC Particle Systems II?
  • How do I move a camera through dust particles created with CC Particle Systems II?
    Posted by Richard Birket on June 5, 2013 at 10:16 am
    Hi all
    I have created a walkthrough animation using 3dsmax. I want to create the effect of subtle dust/pollen in the air. Ideally, I’d like to get hold of Trapcode Particular, but budgets don’t stretch to that at the moment so I am trying to use the in-built CC Particle Systems II to get a reasonable effect.
    I have created some particles with this effect on a solid layer. I have also rendered an RPF sequence and used the keyframe assistant to RPF Camera Import. I am just not sure where to go next.
    How do I ‘look through’ the camera so that it appears to be walking through the particles of dust? Perhaps what I want is not possible.
    John Cuevas replied 13 years, 3 months ago 2 Members · 3 Replies
  • John Cuevas
    June 5, 2013 at 11:48 am
    Use CC Particle World, that will let you use a 3D camera.
    Quick project illustrating how you could do it: 6108_dust.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Richard Birket
    June 5, 2013 at 11:54 am
    Thanks for this. Unfortunately I cannot open your scene as we are only on CS5 (windows). I will investigate CC Particle World.
    Cheers mate!
  • John Cuevas
    June 5, 2013 at 12:47 pm
    It was a pretty simple scene. Fort the particle I used shaded lens sphere, changed the size, color, opacity and opacity over life. Resized the emitter to 1, 1, 2 and adjusted the physics. If you want to open it, you could download a trail version of CS6 from adobe.
    Thinkck.com
