Activity Forums Zaxwerks how do i make the film strip twist or rotate?
  • how do i make the film strip twist or rotate?
    Posted by Brandon on June 6, 2005 at 2:43 am
    I was wondering how would I make the film strip, the one in the tutorial, twist or turn? I want it to start out going kinda straight then curve towards the camera. Also, I want to have a depth of field look too. Where the first part is farther back and a little smaller and the end is bigger as it comes towards the camera. Thanks.
    Brandon
    Brandon replied 21 years, 1 month ago 3 Members · 6 Replies
  • Jon Okerstrom
    June 6, 2005 at 3:05 am
    Hi Brandon,
    Second question first: try adjusting the camera lens to wider angle. This amplifies the difference between how objects near and far appear and should give you what you’re after.
    First question: without looking at the tutorial, I’d use layer cycling to animate the shape of a path which becomes the edge of the film strip in Invigorator. Perhaps this will give you some ideas.
    Jon
  • Brandon
    June 6, 2005 at 4:12 am
    Thanks, I’ll give it a try.
  • Brandon
    June 6, 2005 at 4:36 am
    Ok, I looked for layer cycling, but I couldnt find it. Can you give me a little direction? Thanks.
  • Marcelo Lewin
    June 6, 2005 at 4:22 pm
  • Jon Okerstrom
    June 7, 2005 at 2:40 am
    Thanks, Marcelo,
    Instead of doing a write-on effect as the tutorial demonstrates, simply vary the shape of the stroke slightly in each layer to make the film strip edge appear to animate.
    Jon
  • Brandon
    June 7, 2005 at 3:15 am
    Thank you very much.
