Activity › Forums › VEGAS Pro › how do I make text curve and fade from one color or another?
  • how do I make text curve and fade from one color or another?
    Posted by Adan david on September 1, 2026 at 11:26 am
    Hii! Hope you’re doing well. I was wondering if you could please help me figure out how to make text curve and fade from one color into another? I’m trying to achieve a smooth gradient/fade effect while also having the text follow a curve.
    I’d really appreciate it if you could explain how to do it or point me in the right direction. Thank you so much for your help. Have a great day, and bye for now
    Silviu Negoita
    replied 3 weeks, 6 days ago
    2 Members · 1 Reply
  • Silviu Negoita
    September 1, 2026 at 11:42 am
    Hi Adan! You can do both effects in VEGAS Pro, although they’re easiest to handle separately. For the curved text, one simple method is to use Bezier Masking to create the curve and then adjust the text/positioning along it. If you want the individual letters to actually follow an arc, you can also use the VEGAS Pro titling/text tools that support text-on-path, depending on your version. For the color fade, add a gradient to the text and set the two colors you want at the gradient’s start and end points. You can then adjust the direction and position of the gradient until it looks right.
    Hope this helps, if you need more info watch these! https://www.youtube.com/watch?v=46kJ66VTsiw
    https://www.youtube.com/watch?v=SuAlJ0iUNs4
