Activity Forums VEGAS Pro How do I make “Smooth” the default keyframe shape?
  • How do I make “Smooth” the default keyframe shape?
    Posted by Tor Wong on June 1, 2010 at 7:35 pm
    Friendly greetings!
    I use the “Smooth” keyframe curve type a lot more than the default “Linear”. Is there a way I can set it to default to “Smooth”? I’ve researched documentation and the closest thing I’ve found is selecting all keyframes in a clip, right-clicking and choosing Smooth, but that’s tedious. It becomes even more tedious when I have to do it across multiple clips in a project.
    Also in a similar line of thought, is there a way I can do this with “Disable Resampling”? I notice “Smart” — which is the default — was making too many blurs on my projects.
    Thanks so very much in advance!
    Tor Wong replied 16 years, 3 months ago 3 Members · 5 Replies
  • Mike Kujbida
    June 1, 2010 at 7:55 pm
    What version of Vegas are you using and is it Pro or Movie Studio?
  • Tor Wong
    June 1, 2010 at 8:50 pm
    I’m on Vegas Pro 9.0, thanks for asking.
  • Graham Bernard
    June 1, 2010 at 9:30 pm
    Options | Preferences | External Control & Automation
    Here you will find all the selectable Default options for Keyframes.
    Grazie
  • Mike Kujbida
    June 1, 2010 at 10:40 pm
    Grazie, thanks for filling in for me 🙂
    Torley, I can’t find any way to do this with “Disable Resampling”, even in the internal prefs 🙁
  • Tor Wong
    June 2, 2010 at 12:26 am
    Bingo! Thanks so much Graham and Mike — that’s one very repetitive series of steps removed from my workflow.
    The Disable Resampling is less of a deal; would be nice to do it, but at least I’ve ruled it out as a “feature I couldn’t find” in the meantime.
    Thanks again.
