Activity › Forums › Adobe After Effects › How do I make animated text like this?
  • John Cuevas
    January 7, 2011 at 3:39 pm
    The technique is often referred to as “Kinetic typography”. Very popular style right now. Very doable in AE, I”ve done at least 5 or 6 of these videos in the last year(client sees one on YouTube then asks us to do it…whoohoo).
    Generally a good understanding of precomping, parenting, nulls, text presets, text animators and sometimes 3d cameras and lights are needed to accomplish this type of look.
    That and a whole lot of time, I’ve been using AE for 10 years, and my last Kinetic type video, (about 2 minutes long) took around 25 hours of work.
    Quick google search turned up this tutorial: https://vimeo.com/1271357
    Have fun and good luck.
    Johnny Cuevas, Editor
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jason Mettler
    January 11, 2011 at 4:54 pm
    AE has a lot of built-in text animation presets to get you started. At the top of the AE interface, click ‘Animation’ and then ‘Browse Presets’. Adobe Bridge will open (if you have it installed). In Bridge, search for ‘Text’ and click it. As you dive into the presets, they will sample in the preview panel. Drag into AE any preset that you like.
    Also, to explore further, check out John Dickenson’s 2 videos on Text animation at his site.
    https://www.motionworks.com.au/2010/02/magic-from-presets-1/
    Have fun! The possibilities are huge!
