Activity › Forums › Adobe After Effects › how do i make a splash in water
Posted by Ellen Osborne on January 9, 2013 at 2:51 amI’d like to drop an olive into a martini glass and see a splash as the olive hits the gin. Splash up and settle back down. It doesn’t have to look completely realistic. What’s the best way to do this?
Thanks for the help.
EllenEllen Osborne replied 13 years, 8 months ago 2 Members · 7 Replies -
Joseph W. bourke
January 9, 2013 at 2:26 pmThe only way to do this convincingly is by using a 3D package – Blender is free, and comes with liquid simulation, but also has a relatively steep learning curve.
To keep it in AE you would have to use a third party plugin, I would suggest either Freeform, which I know nothing about, or Newton, which I own, and which is pretty good at liquid simulation via large numbers of particles, and the only true physics simulator for After Effects. You have to fool the eye, but there
are a couple of samples on the website which will show you whether it’s good enough for what you’re doing:https://www.motionboutique.com
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Ellen Osborne
January 9, 2013 at 3:50 pmThanks. I’ll check these out. I don’t have time right now to learn new software. The piece i’m working on is animated from hand drawings, so i think i’ll just try to work something up in photoshop, unless someone has an idea for AE.
Joseph W. bourke
January 10, 2013 at 3:32 pmIf I know Dave, that’s exactly what he means, and it’s probably the best way to achieve what you’re looking for. In terms of time and expense outlay – your materials couldn’t get much cheaper. The only thing to bear in mind is that you might want to shoot it with something that will do at least 60fps, so that if you slo-mo it, it will look good. It all depends on the look you want to achieve.
Joe Bourke
Bourke Media
Ellen Osborne
January 10, 2013 at 3:38 pmsounds like fun. i’ll give it a try. of course, then i have to learn how to remove the background from a moving image and I don’t have the slightest clue on how to do that. Can you direct me to a tutorial?
Ellen Osborne
January 10, 2013 at 6:04 pmI probably need to clarify. The animation that I’m working on has a cartoon aesthetic, so I’m not looking for reality. I want a cartoon splash. So even if I filmed it, I’d probably end up doing some kind of filter on it to bring it back into my cartoon world. What I might do, is film it, then draw over the frames in photoshop and just use the film as a guide. I was hoping that there was some way to just dial in “splash” in AE, but it looks like if that’s what I’m after I need to go third party.
Thanks for the ideas. You guys are terrific.
Ellen Osborne
January 11, 2013 at 4:54 pmThat’s what I did and it worked out great. A splash doesn’t do what we might imagine. Looking at it frame by frame was fascinating.
