Activity Forums Adobe Encore DVD How do I make a button that will go to the next menu?
  • How do I make a button that will go to the next menu?
    Posted by Mike Costantini on November 9, 2006 at 10:37 pm
    I’m new to Encore DVD, watched the Lynda.com training video and am doing pretty well so far. I’m having trouble figuring out how to have a simple arrow graphic (from the library) be the button that goes to another submenu. Can someone tell me how to do this?
    Joe Bowden replied 19 years, 10 months ago 2 Members · 3 Replies
  • Joe Bowden
    November 9, 2006 at 11:33 pm
    Drag the button from the Library into an open menu.
    Convert it to a button.
    With the button selected, go to Properties, click in the Links field and link it to the menu you want.
  • Mike Costantini
    November 10, 2006 at 12:29 am
    I got it, thanks! I also discovered something else too. If I want to use highlight group 2 for that specific button, I could only change it to (=2) IN photoshop. couldn’t figure out how to change it in Encore. In other words, if all of my chapter selection subpictures are yellow when selected, I wanted the button for the next menu to be dark red when in normal state, and brighter red when selected. The only way I could do it was to go in photoshop and change the (=1) to (=2).
    Which leads me to ask what the “Highlight:” option is in the properties panel? Its options are Group 1 and Group 2
  • Joe Bowden
    November 10, 2006 at 6:51 am
    Don’t confuse the subpicture layer number (=1, 2, & 3) with the highlight groups- they two are different things.
    Each highlight group can have differerent subpicture layer numbers (unique =1, 2, & 3 values). You set the highlight group in Button properties (select the button, then go to the Properties panel).
