Activity › Forums › Apple Final Cut Pro Legacy › How do I make a button on the
  • How do I make a button on the
    Posted by Delano Bryant on January 31, 2007 at 6:53 pm
    …button bar from one of my favorite transition?
    I want to take a trans that I use often and place it on the button bar. I can add it to my favorites but there isn’t a way to link it to the button bar. Help
    Jeremy Garchow replied 19 years, 8 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    January 31, 2007 at 7:49 pm
    HOw about linking it to a key command?
  • Delano Bryant
    January 31, 2007 at 8:01 pm
    you can’t link a key command to a transition. Other then the defaults that are set.
    Is that the color red you want to use?
  • Walter Biscardi
    January 31, 2007 at 8:09 pm
    [Hdfilmmaker] “you can’t link a key command to a transition. Other then the defaults that are set.”
    Instead of a button, you can create a default project with all the effects you need to use. I do this with Good Eats where I have a project full of favorite Motions, Filters and effects. All I have to do is drag the motion from the project to my timeline.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jeremy Garchow
    January 31, 2007 at 8:25 pm
    So then make that transition the default.
    Jeremy
  • Jeremy Garchow
    January 31, 2007 at 8:31 pm
    Actually I take this back. Select your transition in the effects tab that you want to assign a key command to. When you have it selected in the browser, select Effects > Make Favorite Effects. Now the transition favorites menu you should see that transition as a favorite. Now hit option-j and type in favorite in the search bubble. Scroll down till you see Video transition favorite #1. click that then assign it a key command.
    Jeremy
  • Jeremy Garchow
    January 31, 2007 at 8:32 pm
    You could also drag this favorite and make a button.
    Jeremy
