Activity › Forums › VEGAS Pro › How do I make a 100 minute video (.avi) fit on one DVD at the best quality possible?
  • How do I make a 100 minute video (.avi) fit on one DVD at the best quality possible?
    Posted by Ben Monroe on November 8, 2010 at 7:41 am
    How do I make a 100 minute movie (.avi) fit onto one 4.7 gb DVD at the best “quality”* possible?
    When I load my .avi into DVD Architect Studio it says that the disc space used = 6.4 gb or 135%. The settings I will use are mpeg-2 720/480 16:9. I know that I need to convert my .avi to mpeg-2 in Vegas Studio Pro 10. When I load a New Project (single movie) into Vegas Pro I can convert my .avi by clicking on File – Render As – and finally Save as type: mpeg-2.
    These are my choices for templates:
    Question #1: What NTSC choice do you suggest from the list above?
    (DVD Architect NTSC Widescreen Video Stream?)
    When I click ‘Custom’ next to whatever NTSC video template I decide on, I’ll get these video choices:
    There are a few things I can fiddle around with including:
    • Checkbox for Prioritize quality over speed
    • Video Quality bar going from low (0) to high (31)
    • Variable Bit Rate (I know bit rate calculators like this one can help reduce my file output size)
    • A bunch of check boxes and drop down menus that I really don’t understand
    • Framerate
    Question #2 (multi-parter): I want great “quality”* and a smooth looking film. What would you suggest I fiddle with?
    Should I:
    -Check or uncheck the box for Prioritize quality over speed?
    -Adjust the Video Quality Bar?
    -Change the variable bit rate via predictions from a bit rate calculator?
    -Any other checkbox or dropdown menu from the video and advance video custom settings?
    -Drop the frame rate from 29 to something lower? (I actually don’t need to consider this but I would like to know for future situations)
    -My original .avi file is 23.976 FPS – I know that I would never raise a frame rate but is it ever worth it to change to 23.976 3:2 pull-down for a file that orignally has a framerate of about 23.976 or higher?
    Question #3: Is there anything else that I might of left out in this post that you might suggest I do to make my video quality best as possible for my final DVD?
    ~Thank you to anyone who feels like they can respond to all my questions or just chirp in with their 2¢. You could copy and paste my questions if you want to answer them~
    * “quality” = smoothness (fps…), resolution, bit rate, anything else I might be missing
    John Rofrano replied 15 years, 10 months ago 2 Members · 1 Reply
  • John Rofrano
    November 8, 2010 at 11:44 am
    [Ben Monroe] “Variable Bit Rate (I know bit rate calculators like this one can help reduce my file output size)”
    I would use the DVD Architect NTSC Widescreen sideo stream template. Then use a bit rate calculator to figure out what your Average bit rate should be to fit on a single 4.7GB DVD. Finally, check the Two-pass checkbox and you should be fine.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
