Activity Forums Adobe After Effects How do I interpret Sony MXF S-Log3 footage in After Effects
  • How do I interpret Sony MXF S-Log3 footage in After Effects
    Posted by John Hudson on March 8, 2017 at 11:26 pm
    I am currently working with some footage shot on a Sony F55 in the Raw format with S-Log3. When I import this footage into Premiere it defaults to Rec709 but I can easily change that in the master effect to S-Log3. The problem is I am going to be working with these files in After Effects. When I bring that same video into After Effects it automatically interprets it as Rec709 and that’s okay if only I could change it. If I go to Interpret footage for the video I see in the bottom left corner a button that says “More Options…”. In that window I can select Rec709 or S-Log2. I don’t see the option for S-Log3. How can I interpret footage in After Effects with S-Log3? I have chatted with Adobe but the didn’t really give me an answer. I am working in After Effects Version 2017.1 (14.1.0.57)
    John Hudson replied 9 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
