How do I increase file resolution?
I’m working with a few videos for some home movies I’m editing with Vegas 9 software.
Now Vegas 9 can edit full HD clips (m2ts files), something my previous version of Vegas (vegas 7) couldn’t. So while my newer clips I can just use m2ts files with full 1280×720 HD resolution, I have older clips that are no longer on my camera and the only copy I have are the rendered mpg files from Picture Motion Browser, which are only 720×480 standard definition resolution.
There is obviously a very visible difference in resolution when editing, and I was wondering if there was a way to raise my SD clips to the full 1280×720 definition to edit with my newer HD clips.
I’ve tried rendering out the old files into new wmv files, with 1280×720 resolution set during rendering, but while it is bigger than before it is still visibly off, which makes a difference in editing. I tried setting “do not letterbox” but that only makes it worse.
What should I do?
