Activity › Forums › Apple Final Cut Pro › How do I import a .fcpxml file?
Posted by Sam Caino on February 15, 2014 at 5:14 amI created an .fcpxml file from Sony Vegas and I am trying to import it into Final Cut Pro X (10.0). I can’t find any menu item to import an .xml. Disclaimer – this is the first time I have even opened X. Is importing an .fcpxml something that was introduced in a later version? Or am I just not seeing the command?
Sam Caino replied 12 years, 6 months ago 4 Members · 5 Replies -
Andreas Kiel
February 15, 2014 at 4:39 pmThere is no fcpxml import in 10.0 – upgrade to the actual version.
-Andreas
Spherico
https://www.spherico.com/filmtools
X-Files Pro, tools for working with FCPX
https://www.spherico.com/filmtools/X-Files/index.html“He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil -
Oliver Peters
February 15, 2014 at 9:34 pm[Sam Caino] “I created an .fcpxml file from Sony Vegas”
No you didn’t. AFAIK, Vegas cannot write an FCPXML file. You probably exported a different type of XML. If the 7toX utility can read this, it will convert it to an FCPXML, which can then be imported into FCP X. You should update your FCP X version if it truly is 10.0. Current is 10.1.1, but that requires Mavericks. Up to 10.0.9 will run up to OSX 10.8.5.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Jeremy Garchow
February 15, 2014 at 10:16 pmVegas does support FCPXML 1.2
https://www.sonycreativesoftware.com/images/products/vegaspro12/VP12_InteropSpec.pdf
Andreas is right. You need at least 10.0.1 for FCPXML, and really you probably should update to 10.1.1.
Jeremy
Oliver Peters
February 15, 2014 at 10:27 pm[Jeremy Garchow] “Vegas does support FCPXML 1.2”
Really? Interesting. I stand corrected. Thanks.
– Oliver
Orlando, FL
Sam Caino
February 16, 2014 at 3:33 pmVegas has a drop down menu that gives you XML options for fcp x, 7, premiere, protools, and a few others.
