Activity › Forums › Avid Media Composer › How do I import a 16×9 AE project into Avid?
  • How do I import a 16×9 AE project into Avid?
    Posted by Milton Hockman on February 4, 2006 at 10:04 pm
    I created a 16×9 bumper in after effects and saved it out as a quicktime movie.
    i need to be able to use this bumper in a 16×9 sequence and a 4×3 sequence.
    I use Avid Xpress Pro HD.
    How do I use my 16×9 bumper in the 4×3 sequence without the 4×3 sequence squashing it?
    I know in Final Cut Pro, you can adjust settings for individual sequences in the same project. I am able to create a sequence at 16×9 settings, and then drag that sequence into another sequence that has 4×3 settings, and the 16×9 sequence will look letterboxed correctly in the new 4×3 sequence.
    Is that possible with Avid Xpress Pro HD?
    anyone know what I can do?
    thank you.
    Jon Zanone replied 20 years, 7 months ago 2 Members · 1 Reply
  • Jon Zanone
    February 6, 2006 at 12:24 pm
    In the effects pallet, under ‘image’, there is a resize effect. Drag that FX onto your clip, and it will fit yoru 16:9 footage into a 4:3 frame.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
