Activity Forums Boris FX How do I hear audio from the audio track in Avid while Pan and scanning?
  • How do I hear audio from the audio track in Avid while Pan and scanning?
    Posted by Malcolm Barton on October 27, 2010 at 9:37 pm
    Hi, I am trying to get used to Boris FX. I am trying to do the Ken Burns effect slowly zooming out of an image. What I want to do is to be able to listen to the audio that is in the audio track in Avid while I am scrubbing and adding keyframes and previewing in Boris. There is an option to add an audio track from a file but that is not what I want.
    If I use Avid’s own Pan and Zoom filter I can preview the clip and hear the voiceover in the audio track. This is invaluable in positioning the keyframes. In Boris it seems like there is a lot of guesswork and having to render the effect to see how it matches up with the voiceover track.
    Or am I missing something?
    Malcolm
    Glass Onion replied 15 years ago 3 Members · 5 Replies
  • William Busby
    October 28, 2010 at 5:30 am
    Using Red as a plug-in in Avid there’s no other way I know of other than exporting the audio tracks as a wav file for instance, then import that into Red.
  • Malcolm Barton
    October 28, 2010 at 3:35 pm
    Thanks for your reply. I guess I’ll have to do that although I am surprised there isn’t a simpler way. I cannot believe that I am the only one having this problem. Does everyone else just put up with having no audio cues?
    Malcolm
  • Malcolm Barton
    October 28, 2010 at 4:48 pm
    Unfortunatly your suggestion is no good. I export the audio to wave and import it into Boris but when I preview there is no audio. I can hear it when I click “Preview track in seperate window” but not when I preview it in the composite window. I have even selected “preview with audio” but I cannot hear anything.
    This and the fact that Boris is so inredibly slow at doing anything whatsoever means that it is unsuitable for my needs.
    Malcolm
  • William Busby
    October 28, 2010 at 6:24 pm
    If you think about it it kind of makes sense there’s no audio without importing it. Using red as a plugin is for video. There’s nothing to reference regarding audio without importing.
    You could try making sure it’s not muted and also making sure you’re doing a ram preview and at a lower res/quality. But you’re right… I’ve always found Red to very sluggish. After Effects responds so much faster than Red in all comparisons that I’ve found.
    Good luck!
  • Glass Onion
    August 24, 2011 at 1:10 am
    Audio is sorely needed because 90% of video is AUDIO!
