Activity Forums Canon Cameras How do I go from 16:9 mode on XL1s to DVD
  • How do I go from 16:9 mode on XL1s to DVD
    Posted by Luis Guerrero on August 17, 2005 at 8:08 am
    I have FCP 4.5 and DVD Studio Pro 2. I can’t seem to make a dvd that is formatted in 16:9 even if im am in 16:9 in Final Cut.
    Luis Guerrero replied 21 years ago 2 Members · 3 Replies
  • David Jones
    August 17, 2005 at 1:31 pm
    What are your settings in FCP/DVD studio pro?
  • Luis Guerrero
    August 17, 2005 at 3:41 pm
    David,
    I started out with the following setup (See Below) in FCP but when I went to DVD Studio it did not work. However I believe I have figured it out. Please scroll down to see if my new settings are correct. I Believe that the most significant error was to select the Anamorphic setting in either the Audio/Video Settings dialog box and/or selecting the Anamorpic option directly in in the sequence settings menu. With the new settings I am able to export to DVD Studio and maintain the “16:9” look.
    If you have time could you explain what true 16:9 is on video and what does the XL1s do to achieve that look?
    How do the XL2 and the GL2 work in 16:9 mode?
    Thank you to you and everyone on the cow!!!
    -Luis
    SEQUENCE PRESETS
    Frame Size: 720 x 480 Pixels
    Editing Timebase: 29.97 fps
    Field Dominance: Lower (Even)
    Pixel Aspect Ratio: NTSC – CCIR 601 / DV
    Anamorphic 16:9: On
    Video Processing: YUV allowed (8-bit)
    White Point: White
    Compressor: DV/DVCPRO – NTSC
    Millions of Colors (24 bit)
    No Data Rate Limit
    No Keyframes Set
    Quality: 100
    Audio Settings:
    16-bit 48.000 kHz Stereo
    CAPTURE PRESETS
    Anamorphic 16:9: On
    White Point: White
    No Data Rate Limit
    No Keyframes Set
    Quality: 100
    Audio Settings:
    NEW SETTINGS NEW SETTINGS NEW SETTINGS NEW SETTINGS
    SEQUENCE PRESETS
    Anamorphic 16:9: Off
    White Point: White
    No Data Rate Limit
    No Keyframes Set
    Quality: 100
    Audio Settings:
    CAPTURE PRESETS
    Using DV Video for video input
    XL1S using NTSC
    29.97 frames per second
    DV/DVCPRO – NTSC at Best quality.
    24 bits per pixel
    720 by 480
    Using DV Audio for audio input
    Input: First 2 channels
    Rate: 48.000 kHz
    Speaker: on
    Volume: 100, Gain: 0
  • Luis Guerrero
    August 17, 2005 at 4:24 pm
    David I just burned a dvd and played it on a dvd player to a standard television.
    The footaged is letterboxed as expected and proportially correct. I did not use the anamorphic settings in FCP at all eventhough my original video footage was shot using the xl1s in “16:9” mode. Since i am playing it on a standard 4:3 TV it’s not a problem. What would happen if I played the dvd on a wide screen TV?
