Activity › Forums › Adobe After Effects › How do I get the whole clip to RAM Preview
Posted by Andreas Sweden on September 23, 2006 at 8:16 amWhen I use RAM Preview I only get a small section of the clip, how do I set it to RAM Preview the whole clip (20 mins long)
Mylenium replied 20 years ago 3 Members · 2 Replies -
Rafael Amador
September 23, 2006 at 11:29 amTo Preview in RAM 20 minutes film (depending of the preview quality) you would need few hundreds or thousand of Gigabytes in your RAM. You must record on disk.
Go to preferences. Memory & Cache. Enable Disk Cache,
Like that the result of the RAM rendering is recorded in your disk and you can preview longer time that with only the RAM capacity.
salud,
Rafael -
Mylenium
September 23, 2006 at 11:51 am[Andreas Sweden] ”
When I use RAM Preview I only get a small section of the clip, how do I set it to RAM Preview the whole clip (20 mins long)”Umm, that’s impossible. Guess why it is called RAM preview – it will only show you frames it can squeeze in the available RAM (or memory)and for standard PAL resolution at full quality that usually is no more than 10 seconds on a 2 GB system. You can increas the length to up to a minute if you use quarter preview resolution, but that’s as good as it gets. Render preview clips at half or quarter resolution to disk, if you really need to check anything longer.
Mylenium
[Pour Myl
