Activity Forums Adobe After Effects How do I get the right perspective in a stereoscopic comp in After Effects?
  • How do I get the right perspective in a stereoscopic comp in After Effects?
    Posted by Hans Castrop on November 30, 2012 at 1:30 pm
    Coming from the stereoscopic forum, Tim Wilson suggested this forum might be a better place;
    I’m trying to figure out a way to correctly superimpose a text in stereoscopic 3D space and animate it in After Effects 5.5. Can anyone point me to some tuts on how to go about this?
    Oke, I’ve seen some tuts on adobe.tv but they don’t cover the actual compositing in real 3D space. I want the text to sit on an object in positive space and finally fly to zero parallax. The camera has a certain field of view and a real object flying to zero parallax would get a certain enlargement, based on that field of view. But how about a computer generated text? it should get bigger but how much? is there a way to figure this out (or a tut that shows me?)
    Hans Castrop replied 13 years, 10 months ago 2 Members · 2 Replies
  • Walter Soyka
    November 30, 2012 at 1:44 pm
    What’s your level of familiarity with After Effects?
    Work with 3D layers in z-space in a comp with a stereoscopic camera rig. As you adjust a layer’s z-position, you’ll get the correct perspectives for each eye.
    If you have footage, you’ll need to track it:
    https://www.videocopilot.net/tutorials/3d_truck_compositing/
    Walter Soyka
  • Hans Castrop
    November 30, 2012 at 1:59 pm
    thanks for quick response
    My level is probably everage.
    I will look into elements3D.
    You say if you have footage you need to track it. do you mean you need to track each eye seperately, cause it might change in depth over time.
