Activity Forums Apple Final Cut Pro Legacy How do I get device control of HDV deck?
  • How do I get device control of HDV deck?
    Posted by Rory Keenan on December 4, 2008 at 8:25 pm
    I’m cutting a documentary and I need to capture some footage shot on a JVC brand HDV camera.
    I believe the footage was shot in 59.94fps at 1080i
    I’m playing the footage on a JVC brand BR-HD50 deck ….. connected to my Mac with firewire.
    Does anyone have experience with this???
    My problem is I can’t get device control of the deck.
    I can play the deck manually and “Capture Now” …. But I’d really like full device control from the log and Capture window.
    The Log & Capture window says “VTR OK” at the bottom
    I’ve tried several different “Capture Presets” but I can’t get device control.
    Do I need Key Span???
    Any help would be appreciated
    -R
    PS (yes I made sure the setting on the deck was switched to “remote”)
    Gregory Butner replied 17 years, 9 months ago 3 Members · 2 Replies
  • Kevin Monahan
    December 4, 2008 at 10:51 pm
    That recorder is not on the list of approved devices to start.
    https://www.apple.com/finalcutstudio/
    Click on supported device guide.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Gregory Butner
    December 5, 2008 at 12:06 am
    I cut a show that is shot on a JVC brand HDV camera that is shot at 720p. I wouldn’t recommend doing anything through the firewire on that deck in to final cut. We use a Kona card to capture footage and control the deck using the 9-pin connector. We also encountered timecode problems with footage that was captured in drop frame. Unless this issue has been fixed I’d also suggest that you shoot in non-drop frame.
