Activity › Forums › Adobe After Effects › How do I get colon mark instead of punctuation mark between numbers?
Posted by Peter Midtvedt on September 10, 2016 at 8:33 amEvery time I try to show the time with the Numbers Effect in After Effects It always ends up with a punctuation mark instead of a colon between the numbers. Is there any way I can change this?
Peter Midtvedt replied 10 years ago 2 Members · 4 Replies -
Walter Soyka
September 10, 2016 at 10:56 am[Peter Midtvedt] “Every time I try to show the time with the Numbers Effect in After Effects It always ends up with a punctuation mark instead of a colon between the numbers. Is there any way I can change this?”
Are you using the “Timecode” type in the Numbers effect?
Personally, I’d use an expression on a text layer like I described in your other thread [link] for maximum control. What input do you have, exactly, and how do you want to format it? More context, more better!
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Peter Midtvedt
September 10, 2016 at 11:45 am -
Walter Soyka
September 10, 2016 at 11:55 amDoes your OS or Ae install use a language other than English?
Check this out for how to format time with a text layer and expression:
https://www.motionscript.com/design-guide/up-down-clock.htmlWalter Soyka
Peter Midtvedt
September 10, 2016 at 12:02 pmYes, my OS is in Norwegian, but AE is in English. I will check out the link you gave me. Thanks.
