Activity Forums Apple Final Cut Pro Legacy How do I fade a video from black and white to color?
  • How do I fade a video from black and white to color?
    Posted by Sebastian Knight on October 31, 2010 at 11:02 pm
    I want to have a clip transition from black & white to color. I would like to know how to do this over 2 minutes period.
    As always thanks in advance for you reply,
    Sebastian
    Thank You in advance for taking the time to read and reply to my Post.
    Sebastian
    Tony Brittan replied 15 years, 10 months ago 4 Members · 3 Replies
  • David Roth weiss
    October 31, 2010 at 11:18 pm
    No one will notice if you do the effect over two minutes.
    In any case, you can export both a color and B&W version, then cross dissolve between the two. Or, export a color version and keyframe the saturation parameter in one of the color correction filters.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    http://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Rafael Amador
    October 31, 2010 at 11:19 pm
    Hi Sevantian,
    The easiest way would be applying any filter where you can bring the Chroma down; then key-framing the Chroma. However this will yield a very poor B&W look.
    I would make two versions of the same clip (B&W and full color) and then make a dissolve or keyframe the opacity of the colored one.
    rafael
    http://www.nagavideo.com
  • Tony Brittan
    November 1, 2010 at 3:22 am
    Try putting your clip on the timeline, 3-way CC and take saturation all the way down (or whatever BW method you prefer using filters), use the blade tool and split the clip in the middle, then remove the filters on the second half, and put a cross dissolve between the two halves and make the transition as long as you’d like it to be.
    Tony Brittan
    Apple Certified Pro – FCP
    Owner – Island Shore Productions
