Activity Forums Adobe Premiere Pro How do I export a marker list with CS4?
  • How do I export a marker list with CS4?
    Posted by Jasmine Kim on November 26, 2013 at 8:45 pm
    I’m still using CS4 and need to export millions of markers as a txt-esque format with timecode and name. – name: the one you type in when you create a marker
    I know FCP has this option but am having a hard time finding it in PP CS4.
    I created markers using “Flash Cue Marker” simply because I didn’t see “set unnumbered marker” button in the sequence window.
    If CS4 doesn’t support this function, that means I’d have to type timecode, name of the marker manually on excel sheet and I only have about 50-70 markers…. ugh.
    Thanks for you help in advance.
    Jasmine Kim replied 12 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
