Activity Forums Adobe After Effects How do i edit out a person from a another video to insert the person to another background?
  • How do i edit out a person from a another video to insert the person to another background?
    Posted by Christopher Khouri on August 27, 2016 at 9:57 am
    As the title says how do i edit out a person from a another video to insert the person to another background?
    Christopher Khouri replied 10 years ago 2 Members · 2 Replies
  • Walter Soyka
    August 27, 2016 at 11:10 am
    You need to isolate the person from their background by either keying [link] or masking [link].
    When planning ahead for this, you record the person in front of an evenly-lit green or blue screen. This makes keying straightforward and practical. Without a background designed for chroma keying, you’ll have to animate masks over the person, tweaking them on every single frame. This is called rotoscoping [link], and it’s laborious. Ae has some tools called Roto Brush, Refine Edge, and Refine Matte which can help quite a lot with this task. Be sure to read the Roto Brush documentation [link] before you start, as it can be a bit tricky to use.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Christopher Khouri
    August 27, 2016 at 1:03 pm
    Thank you for the answer. I will try learning how to use the roto brush 🙂
