Activity Forums Apple Final Cut Pro Legacy How do I edit images in fcp 7 without having to render them
  • How do I edit images in fcp 7 without having to render them
    Posted by Terence Nance on April 4, 2010 at 4:28 pm
    I’m cutting an animatic together for an animated section of my film. I drew the storyboards and scanned them in, re-sized them to 640 x 360px and saved them as jpgs.
    I set up my sequence preset to pro-res LT 640 x 360 23.98fps with a square pixel aspect ratio.
    When I attempt to drop my images into the sequence for editing I get the dreaded red render bar and must render every single edit. It is very laborious and I know at some point in the past I was able to edit images without rendering.
    I tried 80 other codecs, all the different pro-res codecs, the animation codec, none, the dv codecs, nothing worked.
    I tried to use all the image file types i could think of: png, jpg, gif, psd, tif, bmp, nothing worked.
    this is what it all looks like. https://blkcinematheque.com/fcpimages.png
    as you can see in the Viewer window I haven’t changed anything about the image that would require me to render it.
    Please anyone put me up on a workflow for editing still images that will allow me to avoid all the rendering.
    thanks.
    David Roth weiss replied 16 years, 5 months ago 3 Members · 2 Replies
  • John Fishback
    April 4, 2010 at 10:32 pm
    I’d scan your pix at 1280×720. Keep the ProResLT. You’ve given FCP a non-standard frame size and it’s trying to unsuccessfully scale the pix in real time.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • David Roth weiss
    April 4, 2010 at 11:14 pm
    How much installed RAM do you have?
    The amount of system RAM in gigabytes and the collective gigabytes of all unrendered stills has pretty much a one to one relationship to realtime performance, but only up to a point. Because FCP at this point is still a 32-bit app, it can only use just so much RAM. So, even increasing RAM substantially won’t give you a tremendous amount of increased RT when editing/animating stills.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
