Activity Forums Adobe Photoshop How do i edit and then save a png sequence?
  • How do i edit and then save a png sequence?
    Posted by Richard Garabedain on August 18, 2017 at 3:19 pm
    What are my limits. I want to add filters and adjustment layers to a png sequence and then save it and import it into after effects as video. I have been searching but haveni found any good answers or tutorials. I even treid it myself but nothign happens.. it imports 1 frame and tells me thats the sequecne..but when i edit and save its only that one image.
    Ian Watkins replied 8 years, 10 months ago 2 Members · 2 Replies
  • Richard Garabedain
    August 18, 2017 at 4:09 pm
    OKay..i did get it to render out video but myeffects are still pretty limited…anyway to expand or thats all i get
  • Ian Watkins
    September 25, 2017 at 10:13 pm
    First off, have you tried going to File > Export > Layers to Files ?
    It’ll prompt you and ask you what kind of file you want and where to export it. Then when you go to import into After Effects, select all the files you wish to import and the click “import as sequence”. I believe that’ll get you what you’re looking for.
    Why not try doing all your adjustments and color corrections in After Effects instead? It’s an easier workflow for me, personally.
    Hope that helps
