Activity › Forums › Apple Final Cut Pro Legacy › How do I crop 720×480 to 720×306 / 2.35:1 ratio?
  • How do I crop 720×480 to 720×306 / 2.35:1 ratio?
    Posted by Chris Dukes on August 4, 2006 at 2:11 am
    I added a 2.35 Widescreen Matte to my footage and I wanted to export it without the letterbox. But, when I created a sequence of the same settings at 720×306 (what I calculated as 2.35:1) it doesn’t crop right on, or near, where the widescreen masks the footage and leaves thin black bars that look about 15 pixels tall. When I tried adjusting the settings in the sequence a few pixels at a time, it just kept pushing the thin bars further in. Suggestions?
    Mech
    Chris Dukes replied 20 years, 2 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    August 4, 2006 at 4:22 pm
    You are trying to crop in FCP, or are you trying to crop a resulting export?
  • Jeremy Garchow
    August 4, 2006 at 4:28 pm
    Nevermind, I reread your post more throughly this time. So you you are trying to to export a Quicktime movie without the letterbox and you are using FCP to do the encode? What I would do, is export a reference movie out to compressor, and then do your cropping and encoding there.
    Jeremy
  • Andy Mees
    August 4, 2006 at 4:36 pm
    from FCP, Export > Using Compressor…
    in the Compressor app you will be able to adjust the settings, and see exactly how it will affect the ouput, using a live spilt screen view showing both source and target
  • Chris Dukes
    August 4, 2006 at 9:59 pm
    Meaning, I want it to use the exact same settings but just crop it. When I export to compressor, it seems like I have to reset everything.
    Mech
