Activity › Forums › Adobe After Effects › How do I create an old style airport arrivals board?
Posted by Daniel Haskett on July 2, 2008 at 12:03 amHi there
Basically Im talking about the old style aiport arrivals board like this https://www.team-triplet.com/TTimages/2004/P5316439.jpg where the letters kind of flip down when it changes…do you know what I mean?
Does anyone have any tips on how to create that kind of effect in After Effects?
Thanks in advance!
Dan
Drey Tosi replied 16 years, 1 month ago 6 Members · 5 Replies -
Jerry Renes
July 2, 2008 at 7:38 amHi Dan,
I once made a sort of flipbook animation which worked in the same way.
Some points of attention:
Create the board background.
Make the flips with their anchor point at the bottom
Place the flips 1 pixel above the background and turned 90 degrees up.
OR make the whole flips in Photoshop OR link text layers to them.Animate a single flip layer and then duplicate it several times and offset those layers to form a flip sequence. Make sure that the layers that are later in time are on top of the other layers. (You can precompose this sequence to tidy up your main comp if you wish, but then you have to add the letters for the flip sequence in that pre-comp.)
A good way of doing a “flip through and stop” is to take the flip sequence and later in time put the flip (and letter) animation you want to stay visible later in time on top of that.
Put one or two lights facing the background on the top and bottom half, this adds shadow and makes the effect more realistic.
Turn on the motion blur.You can make a standard flipthrough sequence or make every flip sequence “real”, depends on what you want exactly.
That’s all what I can think of now. It’s still early here 🙂
Good Luck!
Jerry
Frank Weber
July 2, 2008 at 9:33 amI just made one of those, well an old alarm flip-clock really, same thing I guess.
Split the letters through the middle, just like the real ones and then animate their rotation in After effects – 3D.
Simple. -
Anthony Popolo
July 2, 2008 at 10:00 pmThis effect already exists in Apple Motion and takes about 10 seconds to create.
Create the text, then apply the Live Font called “Flip Count”. It then creates the whole flip board look, complete with shadows, highlights, staggered flip sequences, etc. -
Thomas Mcmurry
January 30, 2010 at 9:52 pmI want to do the same.
kayak.com does a great job.
is that all AE or is that a 3D program?
Whats the best process to make text updatable?
Thx
Drey Tosi
August 7, 2010 at 7:36 pmCould the single animated digits be mounted in a html table and work as a counter, like a vote?
Could someone do it for me?
