Activity Forums VEGAS Pro How do I create a carousel effect with images?
  • How do I create a carousel effect with images?
    Posted by Nigel O’neill on April 25, 2013 at 12:57 am
    What Vegas plugin or 3rd party app can I use to create to create a rotating carousel effect of images? I want the images to circulate in 3D space with the main image visible in the foreground, but other images circulating in the background but out of focus until they cycle into the foreground view. I have seen it being done on network TV, and am wondering if it is at all possible to do in Vegas.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
    Steve Rhoden replied 13 years, 4 months ago 7 Members · 7 Replies
  • 7 Replies
  • Mike Kujbida
    April 25, 2013 at 1:08 am
    See if Scattershot 3D from VASST will do what you want.
    https://vasst.com/store/scattershot-3d.aspx
  • Paul Beller
    April 25, 2013 at 8:56 am
    scattershot inside vegas and always after effects for the outside job. scattershot may even be simpler as i think there are presets for more or less what you want which you can just adjust to your needs
  • Pete Baratta
    April 25, 2013 at 9:55 am
    You can also try Bluff Titler. There’s a similar circle effect done with photos which could also use
    video clips. You can probably check it out on their website first, Pete
  • Roger Bansemer
    April 25, 2013 at 12:22 pm
    Scattershot is fabulous. Depending on how many pictures you want to include, it can take a very long time to render but that plug in will certainly do the trick.
    Roger Bansemer – PaintingAndTravel.com
  • Nigel O’neill
    April 25, 2013 at 1:33 pm
    Thanks to all
  • David Alfredo
    April 25, 2013 at 1:54 pm
    excuse my ignorance, does this extension use some kind of GPU acceleration for rendering or just relies on the basics provided by the host ? we use some third party plugin at my workplace to streamline photo montages but I’m impressed with John’s work, might try to convince the IT guys but it will be hard (“if it ain’t broken…”)
  • Steve Rhoden
    April 25, 2013 at 2:35 pm
    Yep, VASST ScatterShot 3D is also what i highly recommend.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
