Activity Forums Adobe After Effects How do I create a 16×9 for a SD DVD? ASAP …of course!
  • How do I create a 16×9 for a SD DVD? ASAP …of course!
    Posted by Kevin Dennis on November 11, 2008 at 3:54 pm
    I’m sorry if this question has been posted before.. I looked but could not find the answer I needed.
    How do I create a file that will be played on a HD TV but from a SD DVD player?
    I will be creating the file from scratch, no source footage, all graphics with an animated background. Do I start with an HD or an SD comp in AE? Then after the source file is created what setting do I use in Encore?
    Working in CS3.
    Thanks Kevin
    Kevin Dennis replied 17 years, 10 months ago 25,198 Members · 2 Replies
  • Kevin Dennis
    November 11, 2008 at 5:34 pm
    Wow Dave thanks!!!
    The file will never see real HD output. Its for a one time use, HD plasma display at a conference I am creating content for.
    So, just to be clear, you are saying to create the original AE comp as NTSC DV Widescreen (1.2) and then author in Encore also using NTSC DV Widescreen (1.2)?
    Way too easy!!!
    Thank you!
    Kev
  • Kevin Dennis
    November 11, 2008 at 5:59 pm
    Dave,
    Thanks again.
    You and this forum are life savers!
    Kev
