Activity › Forums › Avid Media Composer › How do I copy locators from one video track to another in Media Composer
  • Richard Sanchez
    July 13, 2012 at 10:44 pm
    One trick I’ll sometimes use, especially if the locator is applied to filler, is I’ll make an add edit before and after the locator or range of locators, and then move them using segment mode. Up and down or right and left, it works fine. If your locators are applied to clips, doesn’t work since you’d be moving those clips.
    If that doesn’t work for you, this guy figured out a great solution.
    https://www.posthacker.com/2011/09/avid-locators.html
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Ian Liuzzi-fedun
    July 14, 2012 at 4:13 pm
    How about from source clip to source clip-how is that done?
