Activity › Forums › Apple Final Cut Pro Legacy › How do I convert from DV over Firewire to ProRes422 720×486 during tape capture?
Posted by Josephine Balakrishnan on November 25, 2012 at 6:57 pmHow do I convert from DV over Firewire to ProRes422 720×486 during tape capture?
Rafael Amador replied 13 years, 10 months ago 3 Members · 6 Replies -
Rafael Amador
November 26, 2012 at 1:59 amTry duplicating a DV NTSC capture preset and change the codec for Prores.
If you are capturing from a DV device, I guess you can only capture 720×480.
You need to capture to a fast drive.
rafael -
November 26, 2012 at 4:24 amthanks. I’m taking it in to Davince Resolve. Will that work?
November 26, 2012 at 4:53 amI just tried to change the presets but the compressor is greyed out on all the presets. I tried Premiere but i don’t see a preset capture.
I know it can be done but i think its off a deck which is expensive since i don’t have one.
Rafael Amador
November 26, 2012 at 9:59 am[josephine balakrishnan] “I just tried to change the presets but the compressor is greyed out on all the presets.”
You are right, the codec can’t be changed.
Sorry, i thought could be possible, because HDV can be captured as Prores through FW, but the preset is not editable.[josephine balakrishnan] “I know it can be done but i think its off a deck which is expensive since i don’t have one.”
Is not about a desk about an IO card.
is necessary something like a BlackMagic, AJA, Matrox or similar.
Some are quite affordable, however,you won’t get any benefit on capturing that footage as Prores.
The only you will get is four folds bigger files.
rafael -
November 26, 2012 at 8:14 pmEvidentally these 6 lines (bringing in the ProRes ) makes a big difference when I work in Black Magic Resolve. That’s why its important.
Rafael Amador
November 27, 2012 at 4:10 am[josephine balakrishnan] “Evidentally these 6 lines (bringing in the ProRes ) makes a big difference when I work in Black Magic Resolve. That’s why its important.”
Those 6 lines shouldn’t make no difference at all.
CC applications should be format/definition agnostic.
At least in Apple Color there is no difference on working with Prores 720×480 or 720×486.
The application put out the same size that gets in.
720×486 is only meaningful when you need to print to tape at 10b.
rafael
