Activity › Forums › Apple Final Cut Pro Legacy › How do I consolidate all clips in a sequence to a single hard drive? (FCP7) Media Manager failing..
  • How do I consolidate all clips in a sequence to a single hard drive? (FCP7) Media Manager failing..
    Posted by Dave Chavinsky on August 25, 2011 at 4:55 am
    I’ve made videos for a summer camp that are in 9 sequences. I’ve nested these sequences in one main sequence and have used media manager to copy these files to an external hard drive with 3 second handles. Several clips are missing in this process.
    when I reconnect media, some of them are totally gone, and some are there, but I get a message:
    “some attributes of one or more of the files you have chosen do not match the attributes of the original. This may cause problems within the sequences that are dependent on them.
    The attributes that differed are as follows:
    -Media Start and End
    -Reel
    -Rate
    would you like to try to connect them again?”
    I press continue, and then connect
    another error message:
    “The file does not have proper content to reconnect to ’43_ex_skate_012′ at time 01:02:08:16 in sequence “Extreme Sports”. Click “OK” to make this item independent and go to the next clip or “Cancel” to skip all clips from this file”
    next error message:
    “one or more files did not have enough media to reconnect some clips. Some edited clip items have had their out point adjusted.”
    doesn’t reconnect
    Please Help!
    Think of the children!!
    Shane Ross replied 15 years, 1 month ago 2 Members · 1 Reply
