Activity Forums Apple Final Cut Pro Legacy How do I Conform 29.97 EDL to 23.98 EDL out of FCP5.0?!?
  • How do I Conform 29.97 EDL to 23.98 EDL out of FCP5.0?!?
    Posted by Aaron on November 14, 2005 at 6:18 pm
    Can anyone give me an answer on this?
    I have a 23.98 HD project that was offlined SD 29.97 and I need to Recapture it HD23.98 for the Online. Any Suggestions?
    I have G5 w/ Kona 2 card
    Steven Gonzales replied 20 years, 10 months ago 3 Members · 4 Replies
  • Aaron Neitz
    November 14, 2005 at 6:47 pm
    29.97 edl out of FCP. cinema tools: convert 30->24fps edl
  • Aaron
    November 14, 2005 at 7:13 pm
    THanks!
    Can you step me through the process of Converting using Cinema tools a little more? I’m very unfamiliar to it.
    And this will create a HD23.98 Sequence that I can capture 23.98 HD source from?
  • Aaron
    November 14, 2005 at 7:14 pm
    Can you step through the conform process using cinema tools a little more. I’ve never used it before.
  • Steven Gonzales
    November 15, 2005 at 4:13 am
    Under the file menu in Cinema Tools, export, converted edl, 24 fps from 30 fps, point at the EDL you want to convert.
    It’s always good to run through the menus on a program, and see what’s there, and what’s in the submenu. If you don’t understand what’s there, then you can use help or the manual.
