Activity › Forums › Compression Techniques › How do I compress to a .wav file? Or am I only able to with quicktimes .mov format?
  • How do I compress to a .wav file? Or am I only able to with quicktimes .mov format?
    Posted by Clint Nitkiewicz hernandez on February 21, 2006 at 9:09 pm
    I need to use compressor from final cut pro, to compress a movie into .wav format for the web, as opposed to the .mov’s normally used format? any converters out there, for the mac??
    thanks a lot
    Clint Nitkiewicz Hern
    Gregg replied 20 years, 6 months ago 3 Members · 2 Replies
  • Charles Simonson
    February 22, 2006 at 7:52 pm
    QT Pro will allow you to export directly to a WAV audio file. QT Pro also has an option for .AVI if that would help.
  • Gregg
    March 19, 2006 at 3:24 am
    You can export .WAV directly out of FCP without using compressor. It is one of the options when you Export to Qiucktime. I don’t have the program in front of me right now so I can’t guide you to it, but the option is there. I have used it.
