Activity › Forums › Adobe Premiere Pro › How do I combine multiple project files into one
  • How do I combine multiple project files into one
    Posted by Luke Stenger on September 8, 2009 at 6:39 pm
    I am working with Adobe Premiere Pro CS3 and I have 3 computers setup to use it (quadcore 2.66, 8 gig ram, etc. etc.)
    The project I am working on is a feature length film that has over 30 hours of raw footage. As you can imagine, I want to split up the work load so the computers aren’t crashing, etc.
    What are my options? I would like to split the whole project into a series of projects, but how will I combine them in the end?
    Also, I should mention the footage I am working with is 1080i.
    Jonas Bendsen replied 17 years ago 4 Members · 4 Replies
  • Chris Buttacoli
    September 8, 2009 at 8:05 pm
    Combining all three projects into one just requires importing the pproj files all into another new project.
  • Jonas Bendsen
    September 8, 2009 at 8:23 pm
    But this (importing the entire project) will create the problem you are currently trying to avoid (all your files will be in your final).
    When you are finished, you should import your final sequences into your master Project File. This will import only the files actually used into your final project.
    It’ll take a little bit of time to go sequence by sequence, but it will keep things from getting gummed up.
    If there’s a better way, I’d like to know about it (because this is a pain in the keester).
    This is my life, I edit and edit and edit and edit…
  • Phocas Kroon
    September 8, 2009 at 9:23 pm
    You can also export the AVI’s of each project and import them in a new final project.
    Phocas Kroon
  • Jonas Bendsen
    September 8, 2009 at 9:25 pm
    But this will gobble up a LOT of hard drive space.
