Activity › Forums › Adobe After Effects › How do I color these particles like this in Particular with a layer emitter?
  • How do I color these particles like this in Particular with a layer emitter?
    Posted by Alexa Smith on November 13, 2022 at 12:24 am
    Hey again! I’m trying to add a gradient of colors like this to these particles using a layer emitter, but I can’t figure out how to retain the shape of the original particle system. This is what I’m trying to replicate.
    https://youtu.be/i7PQ9IO-7fU?t=23https://youtu.be/i7PQ9IO-7fU?t=23
    Originally I tried using a custom sprite that was a sphere with these colors, but it had some strange white artifacts and kept flickering as it trailed down to the end, so this is my second option.
    I tried to keep the same settings as my original system (which was just a solid blue color) but the particles don’t keep the same shape and go everywhere. Any idea how to recreate this effect? Thanks!
    Graham Quince replied 3 years, 10 months ago 2 Members · 3 Replies
  • Graham Quince
    November 14, 2022 at 8:12 pm
    There’s lots of particles going on there, can you let us know when in the video you’re trying to recreate?
  • Alexa Smith
    November 15, 2022 at 5:32 am
    I’m trying to recreate her mane. I have a particle system with a bit of turbulence and the size decreasing over time, I just can’t figure out how to apply those 4 colors to it in a line like that.
  • Graham Quince
    November 15, 2022 at 11:55 am
    Is particles the best way to achieve this? With any simulation tool you have to spend a lot of time setting up the parameters and tweaking them, whereas if you had a shape with a wiggle on it, all you have to do is attach it to the pony’s head.
    It might also be worth checking out the free plugin, Fake Dynamics: https://www.youtube.com/watch?v=uBSouq8feSchttps://www.youtube.com/watch?v=uBSouq8feSc which can handle the broad movement changes for you.
