Activity Forums Apple Final Cut Pro Legacy how do i check the compatibility of converted files?
  • how do i check the compatibility of converted files?
    Posted by Nigel Askew on December 7, 2009 at 5:53 pm
    I’ve used MPEG streamclip to batch convert a large amount of MPEGs, and am happy with the quality of the conversion. They’re all now MOVs, but I’ve heard someone say that MOVs can still be unwieldy, and am worried they may not be 100% compatible with Final Cut Pro. Is there anyway I can check this?
    The codec i used is HDV 1080i50
    Raymond Tuquero replied 16 years, 9 months ago 2 Members · 1 Reply
  • Raymond Tuquero
    December 7, 2009 at 7:07 pm
    If quicktime can read the file fine then Final Cut Pro can read the file. When reading codecs final cut is very dependent on Quicktime.
    -Raymond Tuquero-
    Houston Based Freelancer
    http://www.rtuqvidere.com
