Activity Forums Sony Cameras How do I change the format of F800 to record SD IMX50 16:9?
  • John Sharaf
    June 5, 2011 at 9:35 pm
    That normal. Leave at 1080 for better internal downconvert
  • Ian Cook
    June 6, 2011 at 2:08 pm
    Menu O-27, Rec Format. Set System Line = 1080, System Frequency = 59.94i, Rec Format = IMX 50, Aspect Ratio = 16:9. The Aspect selection is not available until you select an SD format.
